5/25/2011 8:33 AM | |
Joined: 3/21/2006 Last visit: 11/1/2024 Posts: 10229 Rating: (1181) |
Hello, 6ES7313-6CF03-0AB0 CPU313C-2 DP, 16DI/16DO, 64 KB SIMATIC S7-300, CPU 313C-2DP COMPACT CPU WITH MPI, 16 DI/16 DO, 3 FAST COUNTERS (30 KHZ), INTEGRATED DP INTERFACE, INTEGRATED 24V DC POWER SUPPLY, 64 KBYTE WORKING MEMORY, FRONT CONNECTOR (1 X 40PIN) AND MICRO MEMORY CARD REQUIRED Connector and MMCshould be ordered separately. MMC - Which memory cards can you use with a S7-300 CPU? 40pin connector - Which front connector do you need for S7-300 analog/digital modules and for S7-300 compact CPUs? Best regards, Hristo Mihalev |
5/25/2011 11:31 AM | |
Joined: 12/12/2005 Last visit: 3/17/2024 Posts: 180 Rating: (12) |
Hi, |
Last edited by: Heksu at: 5/25/2011 11:42 AM"Beer is proof that God loves us and wants us to be Happy"-Benjamin Franklin |
5/25/2011 11:49 AM | |||||||||||
It depends what will do - now and for future. If it is just for test you could use STEP 7 Lite. This is free of charge software and is possible to be used in S7-300. BUT http://support.automation.siemens.com/WW/view/en/31031123(there have some restrictions - unfortunately). The other ways - as Heksu shew you, I suggest you Step7 5.5
or Step7 Professional 2010:
5/25/2011 12:06 PM | |
Posts: 20 Rating: (0) |
How much will the software costs? |
5/25/2011 12:38 PM | |
Joined: 9/1/2005 Last visit: 11/14/2024 Posts: 4113 Rating: (195) |
Dear Users, if you need prices about our products, please contact your local siemens partner. Here Contacts Worldwideyou will get contact data for your region. Only your local partner will be able to inform you about the local prices in your region. Every other information aren't bindingly. Good Luck for your project! Best regards CS Moderator |
Last edited by: CS Moderator at: 5/25/2011 12:40 PMtypo My Forum is the place to personalize your profile, |
5/25/2011 4:43 PM | |
Joined: 5/28/2008 Last visit: 11/6/2024 Posts: 4516 Rating: (839)
Hello bite me,
I have a nice sugession for you which may be cheaper for you. You can order theS7-300 starter promotion package 6ES7313-5BF03-4YB0 SIMATIC S7-300, STARTERKIT 2009 MULTILINGUAL, WITH CPU313C, STEP7 V5.4 FLOATING LIC., PC-ADAPTER INCL CABEL, 64KB MICRO MEMORY CARD, RAIL 160MM, FRONT CONNECTOR, MANUAL COLLECTION, Hope this helps. |
Ayman Elotaify |
