3/16/2008 10:45 PM | |
Joined: 8/25/2005 Last visit: 5/15/2024 Posts: 1161 Rating: (110) |
Hello Akal_00, you havn't wrote something about the firmwareversion you are using. This is what I found within the Product Support searching about Firmware: Operating system updates for S7-314 CPUsSo you should be able to check your Firmwareversion. Can you tell us more about your problem? You wrote
What does this mean? Which error message do you get? ... Sabine |
3/17/2008 7:31 AM | |
Posts: 2348 Rating: (263) |
Check if your block is from the right library (copy it once again). |
