3/25/2018 11:51 AM | |
Posts: 9 Rating:
Hello and thanks. I still don't have communication. |
3/25/2018 1:18 PM | |
Posts: 9 Rating:
There is no communication through ethernet |
3/25/2018 3:01 PM | |
Joined: 5/28/2008 Last visit: 8/5/2024 Posts: 4515 Rating:
Hello, Try using another PC and check once again that the Mac address is written correctly. If you cann't connect, then most likely, it's a hardware issue in the ethernet port. In this case, you should send the panel to Siemens for repair or replacing. Hope this helps. |
Ayman Elotaify |
3/25/2018 3:14 PM | |
Joined: 12/18/2014 Last visit: 8/6/2024 Posts: 33498 Rating:
Take a look at this topic. Especially the answer from the User Wizard , 2/28/2018 10:02 AM. |
3/25/2018 4:25 PM | |
Posts: 9 Rating:
Hello. I guess i am going to the rescue solution. I just unzip the file in the USB stick? How can i create it? |
3/25/2018 8:15 PM | |
Joined: 10/25/2016 Last visit: 9/1/2022 Posts: 199 Rating:
Hi, So you found other helper Did you change the interface? from USB to Ethernet? Regard |
