4/13/2021 6:37 AM | |
Joined: 7/4/2018 Last visit: 4/18/2024 Posts: 16 Rating: (2) |
Hi, Currently, I'm using 2 modbus master to read from 1 slave. I used 2 modbus master bcs of the data addressing long distance. The problem now those 2 data_ptr keep on clashing with each other. I tried to use the signal from theblock itself to control the req signal but still the same. Im confused on how the master block starts reading data from slave, which signal should i use to control the seq? ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 04/13/2021 11:14:52New subject after splitting |
