2/9/2024 11:43 AM | |
Joined: 8/3/2009 Last visit: 10/11/2024 Posts: 13911 Rating: (1757)
Hello If the Panel was programmed in Protool then you could go this way: Protool-> WinCC flexible 2008 Sp2 (change device to MP377)-> TIA Portal V14 (or older) (change here to Comfort Panel in same size)-> migrate to newer TIA Version and Change to Advanced Runtime Here are some tipps: https://support.industry.siemens.com/cs/ww/en/view/18796902 https://support.industry.siemens.com/cs/ww/en/view/49752044 Bye Murof |
