(0)| 8/4/2025 6:53 AM | |
Joined: 3/28/2015 Last visit: 12/31/2025 Posts: 727 Rating:
Hello, Have a look at the attached file. ----------------------------------------------------------------------------------------------------- Engineering Software ● STEP 7 TIA Portal configurable/integrated from version: V20 (FW V4.0) / V18 (FW V3.0) or higher; configurable with older TIA Portal versions as 6ES7511-1AK02-0AB0 ------------------------------------------------------------------------------------------------------ Attachment6ES75111AL030AB0.pdf (321 Downloads) |
Eng.Mohamed Ibrahim |
| 8/4/2025 7:13 AM | |
Hello, You can use "CPU 1511-1 PN 6ES7511-1AK02-0AB0" in the TIA software older that V20 and install "CPU 1511-1-PN 6ES7511-1AL03-0AB0" in the real PLC rack without any problem. |
| 8/4/2025 8:57 AM | |
Joined: 7/9/2015 Last visit: 12/17/2025 Posts: 4493 Rating:
Hi, please also check this FAQ: How do you load the project data if the version of the firmware installed in the S7-1500 CPU cannot be selected in the hardware catalog of your version of STEP 7 (TIA Portal)?Regards |
