6/13/2011 12:00 PM | |
Joined: 3/21/2006 Last visit: 4/25/2024 Posts: 10228 Rating: (1181)
Contact with Moderators in order to send the project... |
6/13/2011 1:02 PM | |
Posts: 947 Rating: (45) |
Hello jeevanmark25 |
6/16/2011 8:38 AM | |
Joined: 4/24/2009 Last visit: 2/19/2024 Posts: 2683 Rating: (135) |
Hello together, here is the file sent to me by jeevanmark25. Best regards O_Moderator AttachmentWathba.zip (81 Downloads) |
6/16/2011 11:42 AM | |
Joined: 10/7/2005 Last visit: 5/27/2024 Posts: 3007 Rating: (1049)
Hello jeevanmark25 just some quick intial feedback about one aspect of your config that MUST be changed: You use I/O addresses 352-367 for the DP/DP coupler on the CPU 313/CP342-5 side. This means that your DP_Send and DP_Recv DB must be at least 368 Bytes long with a matching declaration of the ANY Pointers of their calls (you currently only have these areas 16 bytes long). Alternatively (and easier) change the DP/DP couplers I/O addresses to 0-15 for the 300 side which seem to be still unused in it (you can leave them as 352-367for the 400 H side, theI/O addresses to NOT have to be the same acrossthe modules that "couple" each other). Have a look too at the link below for some more tips and tricks (and pitfalls): What should you watch out for when configuring a CP342-5 as DP master? I hope this helps and please let us know what you find. |
Cheers |
