4/5/2012 1:19 PM | |
Joined: 10/11/2006 Last visit: 5/27/2024 Posts: 5853 Rating: (793)
Hello, maybe crane applications match your requirements: https://www.automation.siemens.com/mcms/infocenter/content/en/Pages/order_form.aspx?HTTPS=REDIR&nodeKey=key_9175191&infotype=catalogs For detailed information and application support please ask your local Siemens promotor. |
With best regards, |
4/5/2012 2:25 PM | |
Joined: 4/23/2010 Last visit: 12/31/2023 Posts: 8092 Rating: (872) |
Hello TechTeam, Thank you very much for your reply. The motors in catalogue are 1PH, 1LA etc series. In traction generally DC series motors are used with working voltage ranges from 48 volt to 220 V DC. So I would like to know whether this range is available under Siemens brand name. |
4/18/2012 8:54 AM | |
in such a small voltage range 48...230V I'm not sure whether a Siemens motor is available ?! Siemens has DC motors but with higher voltage, named SIMOTICS DC: https://www.automation.siemens.com/mcms/drives/de/motor/gleichstrommotor/Seiten/Default.aspx?HTTPS=REDIR&stc=wwidt100054 |
