3/19/2018 5:14 PM | |
Joined: 9/27/2006 Last visit: 9/10/2024 Posts: 12282 Rating:
Hello Rajkiran; Have you started by looking for information on the Smarlink Ethernrt support from Schneider? Have you contacted anyone from Schneider to find out if this communication setup is compatible with a Sienmens CPU in any way? https://www.schneider-electric.ca/en/search/smartlink%2Bethernet Although I doubt that you could connect the S7 CPU with Smatlink Ehernet directly, it seems that it is possible to connect Modbus RTU or Modbus/TCP I/Os to smartlink Ethernet hardware: If you beleive that is a possible solution, you would need either a combination of: - CP 3141 (Serial, RS-485) with a Modbus RTU license (6ES7870-1AB01-0YA0) https://support.industry.siemens.com/cs/ww/en/view/27774276 - CP 343-1 with a Open ModbusTCP license (2XV9450-1MB00) https://support.industry.siemens.com/cs/ww/en/view/109755501 Hope this helps, Daniel Chartier |
