1/8/2019 2:58 PM | |
Posts: 2 Rating:
Hi; I have similar problem with Basic Display 6AV6 647-0AF11-3AX0. TIA portal V13 SP2, Wincc advance SP2. I turned off Windows defender, and this did not resolve my problem. If I search with Accessible devices I find him. (SIMATIC -HMI). (attachment) How to fix this problem? Best regards! ------------------------------------------------------------------------------------------ Attachment6AV6 647-0AF11-3AX0.docx (37 Downloads) |
Last edited by: Jen_Moderator at: 1/9/2019 12:36:12 PMNew subject after splitting |
1/9/2019 2:16 PM | |
Joined: 8/3/2009 Last visit: 8/6/2024 Posts: 13467 Rating:
Hello tskvaric Are you sure you have set an IP Adress on the Basic Panel? If I do such a search then I can see the IP Adress of the Panel also (in My Case KTP600 Basic PN). -> Check the basics: https://support.industry.siemens.com/cs/ww/en/view/58522603 https://support.industry.siemens.com/cs/ww/en/view/88633853 Bye Murof |
