11/13/2019 11:20 AM | |
Posts: 16 Rating: (0) |
Hey people, Can you share some documents about OVPN client files configuration on Simatic rtu 3030C, and does Simatic rtu 3030C supports OVPN master files? |
11/13/2019 11:34 AM | |
Joined: 4/25/2017 Last visit: 10/11/2024 Posts: 430 Rating: (66) |
Hi, Maybe this example helps: |
Best Regards, |
11/13/2019 12:39 PM | |
Joined: 9/27/2006 Last visit: 10/13/2024 Posts: 12287 Rating: (2685) |
Hello Ivan; Thé following Application Example discusses secure VPN connection (Open VPN) using very similar equipment that Kisrchlaub08 refers to in his reply: Setting up a secure VPN connection between SINEMA Remote Connect Client, SCALANCE S615 and SINEMA Remote Connect Server: https://support.industry.siemens.com/cs/ww/en/view/109479599 You will find a link inside the document to a FAQ, Which settings do you have to make on a SCALACE S615 to be connected by OpenVPN to the SINEMA Remotr Connect Server. https://support.industry.siemens.com/cs/ww/en/view/109745584 Hope this helps, |
