7/2/2020 10:24 AM | |
Joined: 11/15/2015 Last visit: 5/18/2024 Posts: 179 Rating: (28) |
Dear claude_reckinger Why you are not reading it from the rating plate (type plate) that contains the technical data relevant for the motor! Regards, AttachmentOperating Instructions, Synchronous Motors 1FK7.pdf (426 Downloads) |
Look for alternative not for the correct answer...if this is helping you rate it. |
7/5/2020 5:21 AM | |
Joined: 4/25/2015 Last visit: 4/30/2024 Posts: 96 Rating: (4) |
Thank You for your answer, which parameter should I read? |
7/6/2020 10:23 AM | |
Joined: 10/11/2006 Last visit: 5/23/2024 Posts: 5852 Rating: (793)
Hello please have a look into Library LMoMa. There is a FB (FBLTopoDqTopologyHandling) https://support.industry.siemens.com/cs/ww/en/view/58251583 Please note: This function use Library LDPV1 https://support.industry.siemens.com/cs/ww/en/view/109479553 |
With best regards, |
