11/21/2011 10:37 AM | |
Joined: 9/28/2005 Last visit: 7/10/2024 Posts: 2957 Rating: (242) |
Hi, Read these links: http://support.automation.siemens.com/WW/view/en/41737436 http://support.automation.siemens.com/WW/view/en/40734351 Links above are for S7-1200 series PLCs. If you want to change IP for your HMI then it depends on type of HMI, but if it has Windows CE then use control panel. If its not clear for you how to do it then just download and read manual for your HMI. You will find this topic in manual for sure. |
Best regards, |
3/28/2017 8:53 AM | |
Joined: 3/2/2007 Last visit: 7/4/2024 Posts: 932 Rating: (5) |
... thank you ... |
3/28/2017 10:47 AM | |
Joined: 8/3/2009 Last visit: 7/10/2024 Posts: 13259 Rating: (1684) |
Hello I don´t know if its still in your interest but it is possible to change the IP Adress of a S71200 PLC with Basic Panel 2nd Generation and Comfort Panel. for example: https://support.industry.siemens.com/cs/de/en/view/90114350/93813218187 |
8/9/2020 10:54 PM | |
Joined: 2/19/2020 Last visit: 6/24/2024 Posts: 1 Rating: (0) |
Thank you for this solution, worked fine! |
