1/27/2021 1:43 PM | |
Joined: 3/31/2017 Last visit: 5/21/2024 Posts: 39 Rating: (0) |
Hello everyone. 31916: Encoder 1: Encoder parameterization error (Parameter: 415, supplementary information: 0)
I've found out that I can temporarily solve the drive fault by following the solutions in this topic. To copy the encoder parameters into the safety parameters, click on the button in the attachment (navigation: SINAMICS device >> drive axis >> Parameter >> Safety Integrated >> Actual value acquisition). If this does not solve your problem, the F31916 comes with a fault code that indicates the parameter that was not transferred correctly. This way you can solve the discrepancy between encoder parameter and safety parameter one by one. As soon I accept the encoder data and reset any machine fault, the S120 drive looks good. So I retentively save the data, power off and then again on the control unit and then I'm back with my drive fault. Those are Fine resolution and p415[0] values. SOLUTION |
Last edited by: Dav3i at: 01/27/2021 13:49:35Last edited by: Dav3i at: 01/27/2021 13:53:30Last edited by: Dav3i at: 01/28/2021 13:30:31 |
