3/2/2021 1:05 AM | |
Posts: 1 Rating:
I have the same problem. No respond when given trigger to the Send FB. No SF, No TX and RX led What I've tried : -reset the comm block both send and receive -regenerate the idb, changing the whole block and redownload it -power cycle the ET-200 which the CP connected to -redownload the parameter config on hardware config Still no luck if someone have similar problems and solved it pls let me know Will be much appreciated ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 03/02/2021 11:53:54New subject after splitting |
