(0)| 7/29/2022 12:14 AM | |
Posts: 247 Rating:
https://www.youtube.com/watch?v=PjtKBGGQn9g This video shows backing up an open controller that is using a CFAST card. The procedure for your IPC447D will be very similar: the main difference is that you don't need to hold the mode switch (which doesn't exist on the IPC477D) in MRES: just watch for which FKey on the keyboard you need to press to get to the boot menu in the BIOS. The key item that you will need is a bootable USB stick containing a disk backup utility. The video shows using Siemens' Image and Partition Creator software for this. Other utilities may also work. |
