(0)| 10/15/2024 4:55 PM | |
Posts: 1 Rating:
Dear All! I have an issue with wincc flexible 2008 sp5 not start always shows attached screen when I open it. I tried uninstall and reinstall it,but it didn't help. Anyone have idea how to repair this problem. Thanks Dilip More ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 10/16/2024 06:20:26Image embedded Last edited by: Moderator_Lan at: 10/16/2024 06:23:54Last edited by: Moderator_Lan at: 10/16/2024 06:25:28New subject after splitting |
| 10/16/2024 9:15 AM | |
Joined: 5/6/2022 Last visit: 11/27/2025 Posts: 589 Rating:
Hi In the following link, you can find a similar case as yours. I recommend you to follow what Murof has indicate o try to solve the problem: - "wincc flexible 2008 sp5 advanced cannot establish connection au service Automation license manager" Can you try what he has indicated? Best regards! |
