(0)| 12/11/2024 3:03 PM | |
Joined: 5/6/2022 Last visit: 11/27/2025 Posts: 589 Rating:
Hi Antique_, Regarding the error you receive it would be important to know and do the following: - What version of tia portal and panel image version do you have exactly? - Do you get this error with any project or only with this one? To verify if this error only occurs with a specific project and rule out that it is a panel problem. - I would also try deleting the IM folder of the project: "How do I delete the IM folder of my TIA Portal project?": https://support.industry.siemens.com/cs/pe/en/view/109778709 Compile and reload. Could you try and share this information? Best regards!
