(0)| 5/22/2025 6:23 AM | |
Joined: 3/2/2017 Last visit: 1/5/2026 Posts: 99 Rating:
Hi I am trying to follow this library to implement an external encoder to my project. I am trying to run the project on plcsim but it is not running. Plc is always at stop mode. You can see the attached image for diag buffer. I also tried to run example project of the library it gives the same error. Is it a bug about plcsim or is it about CTRL_HSC_EXT block itself? ps: I am trying to use "Additional Sensor for TO_PositioningAxis" method. |
