(0)| 12/6/2018 9:24 AM | |
Posts: 2 Rating:
Hello to all, I have same problem with Siemens panel TP1200 Comfort, panel stuck at boot logo I cannot connect to panel over LAN and Profibus, it is not possible to make OS upgrade.
Please for help, this was happend also on TP700 also, but it was under guarantee and Siemens fix this problem. ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 12/6/2018 11:01:41 AMNew subject after splitting |
| 12/6/2018 12:15 PM | |
Joined: 9/21/2012 Last visit: 1/12/2026 Posts: 4847 Rating:
In the panel manual, search for "Reset to factory default". There is described what you can do. Comfort panels can't be updated/reset with USB stick. USB stick only works with Basic panels. |
| 1/21/2019 12:44 PM | |
Posts: 1611 Rating:
Hey, did you know this FAQ => https://support.industry.siemens.com/cs/ww/en/view/19701610 ToDo: 2.) Check your "PG/PC Settings" => There must be set "Local Ethernet Card...." 3.) Open "ProSave" 4.) Switch on the panel (note: It could be a long time to start the update) Now, the update should be start.... regards, |
| 5/31/2025 9:51 PM | |
Joined: 4/21/2015 Last visit: 1/7/2026 Posts: 61 Rating:
How?
