(0)| 6/18/2025 4:26 AM | |
Joined: 8/31/2006 Last visit: 12/22/2025 Posts: 5 Rating:
IPC377G Can be enginerred in Portal v15? thankans |
| 6/24/2025 2:00 PM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello WXY the IPC377G cannot be configured in a TIA Portal project. these type of IPC cannot be selected in any TIA version. But you can of course run an HMI or similar on this one. just use a common PC Station in your TIA Portal project and add the IE general networkcards to it for communication configuration. (you can treat it in TIA Portal as a common third party PC) bye Murof |
