(0)| 4/18/2008 6:46 AM | |
Joined: 3/26/2008 Last visit: 10/7/2025 Posts: 51 Rating:
should be the following axis enabled in follow-up mode or as leading axis follow-up disabled? |
| 4/18/2008 8:53 AM | |
Joined: 5/12/2006 Last visit: 12/19/2025 Posts: 22816 Rating:
Hello, the following axis cant be enabled as leading or following. All Axes are enabled normal, the synchronous operation is implemented over the following object an the command _enableGearing. I have attached a little program for test. Regards Christoph Attachmenttest.zip (938 Downloads) |
