(1)| 7/14/2017 12:06 PM | |
Posts: 13 Rating:
Hi everyone! we are struggling with something similar. We have saved documents in the Document structure und linked to planning objects through an available tab (See image) Now we see under the object details (e.g. Pump 001) that there are links to the documents how can we create a query to show for one specific object, all linked documentation? and then even for the whole plant, show for the plant objects which documents are linked? (The manual of a pump is just once saved but it should appear in several rows in the query, as many as same pumps in the plant there are) Many thanks in advance! ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 17.07.2017 10:23:55Neue Überschrift nach Splitten |
| 7/18/2017 11:32 AM | |
Joined: 1/2/2017 Last visit: 12/15/2025 Posts: 211 Rating:
Ok, thanks. I don't have tab untergeordnete verknüpfungen. Is it your custom tab?
| 7/18/2017 11:55 AM | |
Posts: 13 Rating:
Hi! Is not a custom Tab. It is available at: @40|A20|Y00|A10|B30|Y00T00297|A01 (iDB 10.2) |
| 7/20/2017 6:27 PM | |
Posts: 13 Rating:
The problem was solved trough personal message. Many thanks again for your support Jiri! |
