(3)| 12/23/2020 1:22 PM | |
Joined: 7/2/2015 Last visit: 11/13/2025 Posts: 96 Rating:
Hi Pepsi Cola, The Protool an WinCC flexible aren't released to use in a virtualized machine. You can checkit at the Compatibility tool Best regards Troubleshoot_er |
| 12/25/2020 10:23 AM | |
Joined: 3/24/2018 Last visit: 9/12/2025 Posts: 237 Rating:
This is wrong. The Protool an WinCC flexible are released to use in a virtualized machine with out any problem. |
| 12/25/2020 12:08 PM | |
Hi, Can you explain this procedure in detail ? Iam not do it before. Thank you in advance. |
| 12/28/2020 2:06 PM | |
Joined: 9/3/2008 Last visit: 12/9/2025 Posts: 943 Rating:
Hi, About the VirtualBox Extension Pack, you first need to download it from: If you have different version, then look at: https://www.virtualbox.org/wiki/Download_Old_Builds_6_1 https://www.virtualbox.org/wiki/Download_Old_Builds_6_0 |
Michael |
