(0)| 2/25/2009 2:43 PM | |
Posts: 73 Rating:
Hello Please see the attached file. A larger capacity module could theoretically replace the smaller on but the drives will need reconfiguring. Regards Attachment611.pdf (691 Downloads) |
| 3/3/2009 8:23 PM | |
Posts: 271 Rating:
Hello Hacm, If you're not sure how to reconfigure the drives, you should consider contacting your Siemens office and request field service for your machine. Documentation usually will guide you through some of the troubleshooting and commissioning techniques, but it is always safer and quicker to have a reliable service engineer to assist you. Documentation for the drives is at: www.automation.siemens.com/doconweb Hope this helps... |
