(0)| 8/9/2021 10:40 AM | |
Posts: 4 Rating:
Hi, Im trying to get kwh reading for logo web view. So i could monitor kwh consumption. Kwh meter specs: Primary Output pulse Constant: 1000imp/MWh About consumption: Any assistance would be appreciated. Thanks Teemu |
| 8/10/2021 10:08 AM | |
Posts: 4 Rating:
Here is the current program...Threshold triggrer is quite hard to calibrate correctly. This version uses kwh meter 1000impulses / 1kwh I dont understand how that stopwatch block works. AttachmentKwh_metering.zip (568 Downloads) |
| 8/10/2021 7:29 PM | |
Joined: 2/22/2008 Last visit: 4/25/2025 Posts: 2698 Rating:
See example in attachment is for power calculation with stopwatch. The pulse generator B001 is only for simulation. The program is for a kWh meter with 1 pulse per kWh. If you need it for other values, then try to understand the calculation and change it in an approriate way. The stopwatch is not suitable for high pulse kWh meter, then use the threshold trigger. Regards, Scorp AttachmentkWh counter stopwatch.zip (551 Downloads) |
