(0)| 12/1/2021 2:27 AM | |
Posts: 3 Rating:
Hi bergmanu, I want to add 'node-red-contrib-azureiothubnode' to node-red to be able to push data from IoT2040 to Microsoft Azure. Following error pops up after attempting to install iothubnode on node-red:
I understand version 8 is not being supported anymore and we cannot upgrade to a higher version either. I am just wondering if there is any solution to enable us sending data from IoT2040 to Azure using Node-Red? Regards
Last edited by: AminJP at: 12/01/2021 02:29:48Last edited by: AminJP at: 12/01/2021 02:30:58Last edited by: Jen_Moderator at: 12/01/2021 10:21:14New subject after splitting |
| 12/13/2021 10:00 AM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi, I think there is no real tutorial about this here in the forum, but maybe on youtube or somewhere else. But basically you can use the pre-installed MQTT node and use settings as you need for the cloud you want to use. I think everything required can be found in the cloud tutorials or documents. If there is SSL/TLS required, you can check this tutorial on how to setup this with the IOT2040. Best regards! |
