(0)| 4/6/2009 7:58 AM | |
Joined: 9/27/2006 Last visit: 12/30/2025 Posts: 12479 Rating:
Hello RCL; Chapter 6 of the DP/DP coupler is dedicated to diagnostics of the unit; you can get coupler diagnostics over the bus, either for DPV0 or DPV1 master. http://support.automation.siemens.com/WW/view/en/1179382 For example, 1 bit of the diagnostic interface is dedicated to the Ready Status of the coupler; you can interrogate it in your program. Other suggestions can be found in the following FAQ: http://support.automation.siemens.com/WW/view/en/18852586 Hope this helps, Daniel Chartier |
