(0)| 9/27/2022 7:30 AM | |
Posts: 2 Rating:
Dear Forum, I'm currently trying to setup the IOT2050. I downloaded the example image from the Siemens website: https://support.industry.siemens.com/cs/nl/en/view/109741799 IOT2050_Example_Image_V1.1.1.zip (658,6 MB) With Win32 Disk imager I flashed the SD card, I plugged the SD card into the gateway, and powered it on but the STAT light is burning red after 10 seconds. And I’m not able to ping 192.168.200.1 on X2 and X1. In the past I did some projects with the IOT2040, and flashed the SD-card with the 2040 example image (same SD card) the same way. This works fine. Am I missing a step in the process, and what do I need to do to get the IOT2050 working? Thank you in advance Alex |
Last edited by: AlexGooi at: 09/27/2022 07:53:29Last edited by: Jen_Moderator at: 09/27/2022 09:18:43Link optimized. |
