(0)| 4/21/2021 9:46 AM | |
Joined: 3/31/2017 Last visit: 9/30/2025 Posts: 47 Rating:
Thank you for your feedback. I'll test it as soon as possible and let you know. As for the adapter, do you mean something like this? At last, why did Siemens go for mPCIe if M.2 is the standard nowadays? Thank you! |
| 4/21/2021 6:47 PM | |
Joined: 12/12/2016 Last visit: 12/11/2025 Posts: 640 Rating:
Hello, You must check if this adapter you mentioned supports E-Key and A-E-Key, which is standard with the WiFi/Bluetooth cards. I had good experience with this adapter from Renkforce. And regarding the mPCIe Interface: There are still many other cards e.g LTE-Cards or e.g the google Coral, which are largely available as mPCIe, I just meant that for the Wifi-Cards what I am seeing is predominately M.2 which I cannot explain why... Best Regards! |
| 3/22/2022 5:07 PM | |
Joined: 4/17/2018 Last visit: 12/12/2025 Posts: 88 Rating:
Hm...i wonder if this combination could work: Intel Wireless-AC 9260 - Netzwerkadapter : Amazon.de: Computer & Zubehör On my IOT2050 Adv ISAR Image I did ls /lib/firmware and found: /lib/firmware/iwlwifi-9260-th-b0-jf-b0-34.ucode /lib/firmware/iwlwifi-9260-th-b0-jf-b0-38.ucode /lib/firmware/iwlwifi-9260-th-b0-jf-b0-41.ucode /lib/firmware/iwlwifi-9260-th-b0-jf-b0-43.ucode /lib/firmware/iwlwifi-9260-th-b0-jf-b0-46.ucode |
| 3/24/2022 9:07 AM | |
Thanks for the info. What a pity. |
| 2/10/2023 7:00 AM | |
Posts: 1 Rating:
Wie sieht es mit dieser Karte aus? INTEL AC7260: WLAN-Adapter, Mini-PCIex, 867 MBit - s bei reichelt elektronik Wäre die zu empfehlen? Die hätte ich auch noch gefunden. Wireless LAN / Bluetooth Mini-PCI Express [Qcom Combo ZQ802XRACB] kaufen (conrad.de) LG |
| 2/10/2023 9:11 AM | |
Joined: 4/28/2015 Last visit: 4/24/2025 Posts: 3345 Rating:
Hi, you can use the Intel AC7260 - is has been tested and works. You can find a list of tested modules here: https://github.com/siemens/meta-iot2050/wiki Best regards! |
