(0)| 9/15/2023 5:38 PM | |
Joined: 11/8/2017 Last visit: 12/16/2025 Posts: 360 Rating:
Hi, I haven't personally seen this issue, but see attached some screen dumps showing where the ranges are set (you may have checked all of these already). The purpose of Capture2.png is to show that the ranges can also be set at individual Floor levels as well as each of the other Building Elements, i.e. Area, Subarea and Section. The same applies to the actual Building at the top of the tree. Also, you don't mention what version of ABT you are using, but please try and ensure you have all the latest patches installed. If you can't see anything that's causing the issue, then please speak to your local Siemens people who will be able to help you. Regards, AttachmentCaptures.zip (230 Downloads) |
