(3)| 11/20/2023 12:24 PM | |
Joined: 5/6/2022 Last visit: 1/8/2026 Posts: 589 Rating:
HiTyhoon, In this case, if the screen has a license loaded, before updating the image you must make a backup of the license from the ALM so as not to lose it. Here is how to do it: Because in the end, if there is a license and you do a restore, you will lose it. If you lost it, you would have to contact support to recover the license in which they will ask you for the certificate. Best regards!
| 11/21/2023 1:40 AM | |
Joined: 9/1/2010 Last visit: 8/29/2025 Posts: 27 Rating:
Thanks for the feedback, looks simple enough, however there is no options for KTP600 Basic only 400 and 700? |
