(0)| 12/11/2023 10:43 PM | |
Posts: 1 Rating:
PLEASEEE SOME Trato de cargar el PLC pero me sale que el "CPU common" tiene un firmware inncompatible??? que hago?? I try to load the PLC but I get that the "CPU common" has an incompatible firmware??? what I do?? ------------------------------------------------------------------------------------------ |
Last edited by: The Helping Hand at: 12/12/2023 09:54:20New subject after splitting and Text formatting optimized |
| 12/12/2023 10:35 AM | |
Joined: 5/6/2022 Last visit: 11/27/2025 Posts: 589 Rating:
Hi AutoGen_5375055, Was the CPU properly unloaded before and a full build rebuild performed for both hardware and software? Has the PLC memory card been previously formatted? If yes, was it done through the TIA Portal? Have you used the card in another PLC or loaded another program on it? I wait for you response. Best regards! |
| 12/12/2023 3:18 PM | |
Joined: 7/7/2010 Last visit: 12/31/2025 Posts: 16342 Rating:
What FW version PLC? What TIA Portal version (and update) are you trying to use? You may need a higher version of TIA Portal in order to access that PLC.
science guy |
