(0)| 1/10/2024 10:21 AM | |
Posts: 5 Rating:
When I want to log in to my panel, the user input field is filled with the last user name that has been logged in. Can this not be avoided? |
| 1/10/2024 11:46 AM | |
Joined: 7/19/2022 Last visit: 12/23/2025 Posts: 436 Rating:
Hello Erik Skou, If you are using the default viewer to log in you will not be able to do much since it is a system window that cannot be modified. If you are doing it with your own fields, you will have an I/O field associated with a variable that stores the name, therefore, it is normal for that field to show the last value that the tags has. |
| 1/11/2024 8:41 AM | |
Posts: 5 Rating:
Thank you for the answer. |
