(1)| 3/18/2024 8:12 AM | |
Posts: 5 Rating:
We have a CPU 414-2. When we start it after a day of shutdown, all its indicators flash. After turning off the power supply, the CPU turn to stop mode. Upon turning the power supply back on, the CPU switches to run mode, and everything returns to normal. However, after some time, the issue recurs. This pattern repeats every one or two days after each shutdown. I would greatly appreciate your valuable suggestions on this.
AttachmentDiagnose.txt (843 Downloads) |
| 3/18/2024 11:47 AM | |
Joined: 5/30/2022 Last visit: 12/17/2025 Posts: 634 Rating:
Hi AutoGen_5173221, Can you attach a picture of the LEDS? I would say you should add an OB82 to your program, see page 82 of the following manual: AttachmentS7pr___b.pdf (1086 Downloads) |
Last edited by: The Helping Hand at: 03/18/2024 15:11:22File attached from link If this information really helps, you could use the Rate function. |
