(0)| 10/16/2024 10:52 AM | |
Joined: 5/2/2017 Last visit: 11/26/2024 Posts: 14 Rating:
Hi All, I am using WinCC V8.0 and SCC V10 How execute control tags using VB script. Example: single command (GAPCxxxx.xxx.ctl.Value) tags how executed using VB script. I have attached VB Command script. (this one I have written.). During command running x.Cause, x.cmdcounter, x.Validity .... tags are updated. Now xxx.value and xxx.RTValue tags are available in tag management. Now command execute using "SCC_Cmd" ("C" script) function. But in SCC V10, not available During command running x.Cause, x.cmdcounter, x.Validity ....etc tags in tag management. How can I execute command tag using VB script. Please support.... Please describe how to process below tags (xx.RTValue) using vbscript Dim valueTag, valuetypeTag, causeTag, counterTag Set valueTag = HMIRuntime.Tags("GAPCxxxx.xxx.ctl.Value") Set valuetypeTag = HMIRuntime.Tags("GAPCxxxx.xxx.ctl.Valuetype") Set causeTag = HMIRuntime.Tags("GAPCxxxx.xxx.ctl.Cause") Set counterTag = HMIRuntime.Tags("GAPCxxxx.xxx.ctl.CmdCounter") CounterTag.Read valueTag.Value = 1 ' 1 - OFF , 2- ON valuetypeTag.Value = 14 ' ePulsOutputCommand
counterTag.Value = CounterTag.Value + 1 ValueTag.Write ValuetypeTag.Write CauseTag.Write CounterTag.Write Thanks MRK AttachmentVB Command.zip (170 Downloads) |
