(0)| 11/13/2024 3:29 PM | |
Joined: 5/13/2019 Last visit: 7/25/2025 Posts: 34 Rating:
Hi, I am using inputs I7 and I8 as analog inputs. As you will see in the video, the values fluctuate even though the voltage is stable. The 0-10V value is coming from a PT100 - 0-10V converter device for the analog input. However, when I connect a different device, such as a digital potentiometer, the values do not fluctuate. Could you provide some insight into the cause and solution for this issue? AttachmentAnalog.avi (252 Downloads) |
