11/19/2024 7:22 PM | |
Joined: 9/16/2024 Last visit: 7/18/2025 Posts: 10 Rating:
Hello, thank you for your attention. However, I have already performed this procedure before and the same error occurs. I ended up creating a new topic in the form (SDK_Eclipse_Error) and explaining it better, I will repeat it here, I hope there is no problem. In Cross Setting on the Path tab, when I add /home/dalacort/SDK_V1.3.1/sdk-iot2050-debian-arm64/usr/bin to the path, this error appears during compilation.
If I modify and indicate the path only /use/bin, the system compiles and runs, but when I link to the IOT2050 and run it, the error that appears is this:
I appreciate your help. ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 11/20/2024 09:17:25New subject after splitting Last edited by: RDalacort at: 11/20/2024 14:07:59Last edited by: RDalacort at: 11/22/2024 01:22:05 |
11/19/2024 7:28 PM | |
Joined: 12/18/2014 Last visit: 9/17/2025 Posts: 35968 Rating:
Please don't post twice for the same problem. You have made also a own topic: SDK_Eclipse_Erro
