(0)| 12/30/2024 11:02 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello AutoGen_2885365 you can use a online trend control in the background (invisible in a global Screen which is always loaded) here you can trigger the export with a script for example something like this (https://support.industry.siemens.com/cs/de/de/view/25533776) should work similar to WInCC V7/8 or you use tools like PM Open Export for this job (you do not need any programming) or you use the Runtime API of WinCC Professional for exporting the Data: https://support.industry.siemens.com/cs/ww/en/view/109813306/94053502859 Bye Murof |
