(0)| 1/4/2025 1:57 PM | |
Joined: 12/16/2024 Last visit: 2/6/2025 Posts: 1 Rating:
I'm having problems trying to connect to an S7 315-2DP cpu. After setting set PG/PC interface MPI/USB, "download (33:17075)" "online: The local MPI address for the programming device/PC is Higher tahn the maximum node address or the wrong transmission rate or wrong interrupt is set" . Any solution? ------------------------------------------------------------------------------------------ |
Last edited by: AutoGen_6451120 at: 01/04/2025 13:59:39Last edited by: Moderator_Lan at: 01/07/2025 08:30:25Text formatting optimized Last edited by: Moderator_Lan at: 01/07/2025 08:31:49New subject after splitting |
| 1/7/2025 9:08 AM | |
Joined: 7/9/2015 Last visit: 12/17/2025 Posts: 4493 Rating:
Hi, please check general FAQ, perhaps it helps you... Is there a check list for implementing a PC adapter?Regards, Towome |
