(0)| 1/9/2025 8:51 AM | |
Joined: 8/3/2009 Last visit: 1/8/2026 Posts: 16629 Rating:
Hello A Reset to factory settings can only be made with the USB Recovery and NOT with Prosave in case of a Basic Panel 2nd Generation: https://support.industry.siemens.com/cs/ww/en/view/109744950 Use a USB 2.0 Device and a smaller one, I used often older USB Devices with about 2GB and this works good, newer STicks do not work every time. If this do not work, I think you have to send to repair center Bye Murof |
