(0)| 1/10/2025 12:37 PM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello OFERYOSEF yes its true there is no handshake between WinCC and the Printer drivers or the PDF printers if the job is done. If you search for help files or documentation you can have a look at this FAQ: https://support.industry.siemens.com/cs/de/en/view/109977259 -> if you search vor C Script then study the programming manual which is linked in this FAQ Bye Murof |
