(0)| 1/6/2025 9:08 AM | |
Joined: 2/24/2011 Last visit: 1/8/2026 Posts: 96 Rating:
Hi, You use a very old 11abg device here. This type was replaced by 11n devices long time ago. As I remember, information for the configuration was noted in a configuration manual SCALANCE W-700 on the accompanying CD. Please have a look in the manual. Otherwise I recommend to get in touch with the Support.
| 1/8/2025 2:21 PM | |
Joined: 8/3/2009 Last visit: 1/9/2026 Posts: 16629 Rating:
Hello If you have set an IP Address for the device use a fixed IP address in your PC that is connected to in the same subnet.Then open a Webbrowser and enter the IP of the Scalance Login then in the Webbased Management for further settings https://support.industry.siemens.com/cs/ww/en/view/79695884/12585218827 https://support.industry.siemens.com/cs/ww/en/view/33318647 Bye Murof |
