(0)| 2/20/2025 10:39 AM | |
Joined: 6/30/2018 Last visit: 7/21/2025 Posts: 11 Rating:
Hello, I'm trying to configure a workspace from my TIA portal V17 which have PLC and WinCC unified HMI configuration. I wanted to link the project files to my Azure Repo. I can be able to link the PLC project to my Azure Repo Using Git Addin and that Works Fine for me. Same way I cant figure out how to do the same for HMI/Wincc Unified Part. The Question Is: 2) if not from v17, can i Do the same with any other recent TIA Portal Versions? 3) If can't do this from TIA Portal Directly, Is there any work around to achieve this? Either by manual way? help me with the procedure. Thanks in advance Prasadh ------------------------------------------------------------------------------------------ |
Last edited by: Moderator_Lan at: 02/20/2025 11:24:12New subject after splitting |
| 2/27/2025 10:25 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello prsthraja1696 I think you cannot link WinCC Unified Projects to Github. If you are working with scripts you can use external tool for this for example: https://support.industry.siemens.com/cs/de/en/view/109825899 Bye Murof |
