(0)| 2/28/2025 8:33 AM | |
Joined: 8/14/2024 Last visit: 7/29/2025 Posts: 20 Rating:
Hi everyone, I have been assigned to configure the WinCC RT Pro Server-Client setup in a redundant system for the latest version of RT Pro. While searching, I found a document titled Plant Configuration Using WinCC Runtime Professional, but it is not the latest version and is based on WinCC V13. Can I refer to this document for my project? (RT Pro V19/V20) Thank you. |
Last edited by: ShreyasM at: 02/28/2025 08:35:30Last edited by: Moderator_Lan at: 02/28/2025 09:32:41link optimized |
| 2/28/2025 10:48 AM | |
Joined: 2/17/2020 Last visit: 1/15/2026 Posts: 1251 Rating:
Hi, I don't think there will be many changes, but I would recommend you to follow the "WinCC Server - WinCC Client" section of the manual below: SIMATIC WinCC Engineering V19 - Options > WinCC Server / WinCC Client For example, starting with WinCC Professional V16, you need to manually check the "Enable remote communication" box in SIMATIC Shell. See: |
A rating will be well appreciated. |
