(0)| 10/12/2021 9:07 AM | |
Posts: 8 Rating:
Hello, In Unified V17 Update1 I can't change with "Change object references" any item in Properties/Interface of Faceplate object. What am I doing wrong? For basic objects it is working. Thank you in advance Petr ------------------------------------------------------------------------------------------ |
Last edited by: Jen_Moderator at: 10/12/2021 11:19:55New subject after splitting |
| 10/18/2021 3:34 PM | |
Posts: 271 Rating:
Hello spg, you're not doing anything wrong. This functionality is currently not usable for faceplate containers. Best Regards, Fred |
| 12/30/2021 10:29 AM | |
Joined: 9/23/2005 Last visit: 1/9/2026 Posts: 4443 Rating:
Hi, did up2 bring any help? |
Denilson Pegaia |
| 6/28/2024 9:12 AM | |
Posts: 1 Rating:
Options>>Settings>>General>>Cross-reference>>Recreate the cross-reference information |
| 3/18/2025 10:21 AM | |
Joined: 8/3/2009 Last visit: 1/9/2026 Posts: 16629 Rating:
Hello Your screenshot seems that no object is referenced to the selected Io Field. check if there is a tag danymized? Check also in a new test project. Check also if you have installed the latest Upd for your V19 If all does not work you can try THIS, perhaps it helps. Bye Murof |
