(0)| 3/18/2025 10:39 AM | |
Joined: 10/16/2020 Last visit: 12/19/2025 Posts: 146 Rating:
Hi, For a more in-depth review, I would recommend contacting Siemens Technical Support. However, some points to check would be:
BR BRCookie_M0nster |
Last edited by: Moderator_Lan at: 03/18/2025 10:47:48link optimized If this information has been helpful to you, please don't forget to rate it. |
| 3/21/2025 12:16 PM | |
Joined: 1/16/2012 Last visit: 6/30/2025 Posts: 127 Rating:
Hi Murof, The VM is a Windows Server 2019 Version 10.0.17763 Build 17763. WinCC is V7.5 + SP2 + Upd6 and "lets Windows choose what's best for my computer" is selected for performance. I have also attached the WinCC Log. Thanks Best regards, Tech Ahmed AttachmentWinCC Log.zip (176 Downloads) |
| 3/27/2025 9:03 AM | |
Joined: 8/3/2009 Last visit: 12/19/2025 Posts: 16612 Rating:
Hello Tech Ahmed so the Win Server should be a 2019 (Build 1809). Is it a LTSC Verison in your case? its because only the LTSC Version of WinServer 2019 1809 is released with WinCC V7.5 SP2 I´m not sure if this should be the reason but we have to be careful always with software compatibility: https://support.industry.siemens.com/cs/de/en/view/64847781 Bye Murof |
