(0)| 3/31/2025 1:50 PM | |
Joined: 7/11/2024 Last visit: 12/29/2025 Posts: 200 Rating:
Hi Luke Is there a direct connection between PLC and PC or are you using any intermediate device? Try establishing a direct connection Have you tried disabling any firewall or antivirus of your PC? Also, you should take a look at this FAQ: What options are available in STEP 7 (TIA Portal) for uploading when the project version in the CPU no longer matches the version on your PG/PC? Good luck! |
If this post has been useful, don't forget to rate it!😊 |
| 3/31/2025 1:55 PM | |
Joined: 4/7/2022 Last visit: 12/9/2025 Posts: 5 Rating:
Hi there, thanks for your response! I have followed that FAQ and seem to have everything set up correctly. I have not tried with a direct connection to the PLC, I am going through an ethernet switch due to no open ports on the PLC. Perhaps this is the issue. Production seems unwilling to disconnect other devices to let me get in directly, I will see if I can make a plan with that. Thanks |
