4/14/2025 7:21 PM | |
Joined: 9/21/2012 Last visit: 9/16/2025 Posts: 4709 Rating:
Depends on what licenses do you have now? Also what Hardware you need to use? |
4/15/2025 6:57 AM | |
Joined: 4/14/2025 Last visit: 4/16/2025 Posts: 3 Rating:
Hi I can download all of those in my first post. We are currently using 1510 CPU's. Not sure what you are asking about the licence: only received a crash course on the Siemens platform. I have a licence for v20, TIA portal, and HMI. BR
4/15/2025 7:08 AM | |
Joined: 5/6/2022 Last visit: 9/15/2025 Posts: 589 Rating:
Hi AutoGen_754861, I don't know if I understand exactly your problem. In this case, I understand that you have purchased a number of licenses through the ALM, could you send a screenshot of exactly which ones you have purchased so I can tell you what to install or what you need? What you indicate in the forum post in grey are the TIA Portal V20 installation files which include STEP 7 Professional, WinCC, SINAMICs and Safety. This can also be found on the SIOS website: If you install this software, you will also have TRIAL licenses. Therefore, it would be important to know what licenses you have and what exactly you want to program (as you indicate for the S7-1500) to know what you are missing or what you need. Best regards!
4/15/2025 9:15 AM | |
Sry for the confusion. Thank you for your reply. I assumed that I needed to download everything under the download field. SIMATIC STEP 7 Professional V20 DL (6ES78221AE240YA5) BR
4/15/2025 7:08 PM | |
Download Step7 Professional with WinCC Unified and install them. TIA Portal is a framework of many different softwares. It's rare that you would ever need to install all softwares packages that are available. |
4/16/2025 6:31 AM | |
Hi AutoGen_754861, Exactly, in principle when you receive the licenses you also receive download files along with them to proceed with their installation. In your case, you have license for STEP 7 Professional (Programming PLCs) and for WinCC Unified (Programming HMI screens). All other packages would not be necessary. However, as I said, you can also download the software from the link I shared with you. Best regards!
