(0)| 5/8/2025 12:18 PM | |
Joined: 2/21/2014 Last visit: 12/19/2025 Posts: 674 Rating:
You need to go through each and every script code at each and every object in each and every file. You can try the below script. Disclaimer: Make a copy of the original files. The script is not thoroughly tested and some cases may not be covered. Verify with 2-3 files if it works or not as you expect. Make changes if required in the script. The script gives a fair idea how to access the scripts so modifying should be easy. AttachmentReplace_VB_Scripts.txt (110 Downloads) |
You can always use "Rate" and "To Thank" button to appreciate my efforts in helping you :) |
